Get list of ip addresses
Hi all,
I have loki receiving logs like
{"client_ip":"141.147.27.251","duration":"41.000000ms","level":"INFO","method":"POST","path":"/api/v1/play"}
I would like to create a query that can list the IP addresses hitting that endpoint /api/v1/play
Is there a way to create such list of IP addresses? I spent a good amount of time googling but could not find a way to do so.
Thanks in advance for any help.
What kind of output are you looking for?
Easiest query would be something like sum by (client_ip) (count_over_time({SELECTOR} | json [$__interval])), which will generate a time series metrics aggregated by client_ip.
Thank you. It did what I was expecting!
At the end just needed to do the following in my case
sum by (client_ip) (count_over_time({app="my-app", environment="production"} | json | path="/api/v1/play" [$__interval]))
