It is clear that we can make Panels repeat on every value of a template variable.
This si through the edit Panel options as follows:
"**Repeat by variable**
Repeat this panel for each value in the selected variable. "
Is it possible to have series repeat for every value of a template variable. So for example a separate series for each value of the variable?
I can make a solution with the ${foobar:regex} or even the :pipe and it works but this displays all the values of the variable `
foobar
in the same series. I want a seperate series for each value of the variable.
Thanks for any answers
Best
E
