Grafana v10.3.3 (252761264e) -
use aws ec2 describe-images to obtain the following:
- InstanceID that using AMI
- The AMI AmiID
- The Age of the AMI
- The AMI’s OwnerID
- The Name Tag of the AMI
I’ve achieved this using the attached bash script using aws ec2 describe-images, However I need to use Grafana to retrieve the same metrics from the eks cluster and making an API call to AWS accounts. -
What happened?
NA -
NA -
NA -
NA -
Fetch data from any API using Grafana | by Hakim Rouatbi | Pernod Ricard Tech | Medium
Thanks
Michael
