I am successfully able to run query on mysql database.
SELECT (CASE WHEN p.host REGEXP 'sl' THEN 'RHEL' END) AS OS, p.host, p.complete_dt as date FROM table1 p inner join table2 t ON t.queue_id = p.queue_id inner join checklist_runs cr ON cr.tt_id = t.id inner JOIN item_runs cir ON cr.id = cir.run_id inner JOIN c_items ci ON cir.c_item_id = ci.id where p.IS_BACKLOG is null and group by p.host, p.complete_dt;
When I try to run the same query in Grafana using a Graph I am getting an erro
Found no column named time or time_sec
My table and columns look as below
