indi59
February 18, 2024, 5:12am
1
I got a flux query on which it take long time:
the array variable can have 1000 values ~.
ldevname = from(bucket: v.bucket)
|> range(start: -365d)
|> filter(fn: (r) => r._measurement == "LDEV_CNF" )
|> filter(fn: (r) => r.poolid == "${pool}")
|> keep(columns: ["ldevID_cnf"])
|> group()
|> distinct(column: "ldevID_cnf")
|> findColumn(fn: (key) => true, column: "_value")
|> filter(fn: (r) => r._measurement == "LDEV" and r._field == "LDEV_IOPS" )
|> filter(fn: (r) => contains(value: r.ldevID, set: ldevname))
Is-it possible to optimize this one?
Many thanks,
yosiasz
February 18, 2024, 12:36pm
2
The rule with influxdb is as follows:
measurement
and tags
are indexed whereas fields
are not.
So you may want to configure items you are filtering as tags
indi59
February 19, 2024, 7:29am
3
thanks for your reply. but the filter is made on tag, numeric value is well set on field.
yosiasz
February 19, 2024, 7:51am
4
indi59:
contains(value
Then contains is the culprit and notorious for performance issues
nope. is nodename a field or a tag?
create a bucket + token in influxdb2
enable metric export in Proxmox VE. <--- this section is a concern
how much faster is your query now with the regex change
indi59
February 19, 2024, 9:06am
5
I understand, many thanks for links and explanations.
But i already tried with a regex filter but without sucess.
|> range(start: -365d)
|> filter(fn: (r) => r._measurement == “LDEV_CNF” )
|> filter(fn: (r) => r.poolid == “${pool}”)
|> keep(columns: [“ldevID_cnf”])
|> group()
|> distinct(column: “ldevID_cnf”)
|> findColumn(fn: (key) => true, column: “_value”)
|> filter(fn: (r) => r._measurement == “LDEV” and r._field == “LDEV_IOPS” )
// |> filter(fn: (r) => contains(value: r.ldevID, set: ldevname))
filter(fn: (r) => r[“ldevID”] =~ /${ldevname:regex}/)
→ invalid: compilation failed: error @15 :35-15:54: regex parse error: ${ldevname:regex} error: repetition quantifier expects a valid decimal
value of ldevname is composed as follow: xx:xx:xx
yosiasz
February 19, 2024, 12:11pm
6
=~ /^$hostname$/)
Maybe like this style?
indi59
February 19, 2024, 1:04pm
7
An other error:
filter(fn: (r) => r[“ldevID”] =~ /^$ldevname$/)
filter(fn: (r) => r[“ldevID”] =~ /\b${ldevname:regex}\b/)
invalid: error @21 :1-21:48: missing required argument tables
the search “ldevname” has following values:
i need to convert in decimal maybe?
