Flux Query in Grafana Returning Partial Results compared to InfluxDB Data Explorer
    This is Grafana 9.4.3 running on a Linux box
    I am querying my InfluxDB database and trying to show unique assessments (think of it like a tag, with each different assessment/tag having a unique GUID) on a geomap panel. The assessments are being written into InfluxDB every minute, and I want this geomap panel to just show the most recent record of each assessment on the map. I want to be able to select different time ranges, though, so that I can see what assessments were active during that particular time…I just want to limit the data displayed to only the most recent record for each unique assessment ID (there is a field in the data with each assessment’s GUID) so that mousing over each assessment on the map shows that assessment’s information rather than 5 or 10 records (one per minute for the time range selected).
    I am using the following flux query in Grafana:
from(bucket: "Assessment_Data")
  |> filter(fn: (r) => r["_measurement"] == "current_assessments")
  |> filter(fn: (r) => r["_field"] == "assessmentlat" or r["_field"] == "assessmentlon" or r["_field"] == "assessmentid" or r["_field"] == "assessmentcreated" or r["_field"] == "assessmentcomments" or r["_field"] == "assessmentcreatedby" or r["_field"] == "assessmentelement" or r["_field"] == "assessmentfeeder" or r["_field"] == "assessmentcategory")
  |> pivot(rowKey: ["_time"], columnKey: ["_field"], valueColumn: "_value" )
  |> drop(columns: ["_start", "_stop"])
  |> group(columns: ["assessmentid"])
  |> last(column: "_time")
Any help on this would be much appreciated.
Well, never mind on that. I was able to fix the problem. Using the Query Inspector with my original query (I’m still fairly new to Grafana, and this is a relatively unexplored feature for me), I was able to look at the queried data and realize that I was getting data back in two data frames, but only one of them was being graphed on my geomap panel.
This rang a bell for one of the transforms that I had previously tried to make work for something unrelated and had gotten a message about it being designed to work with multiple frames, which I had never understood previously. Searching through the Transforms, I came upon the “Merge” transform, which combines multiple data frames into one output. As shown below, this fixes my problem beautifully.
I’ll leave this thread here in case it ever helps anybody else discover this one extra needed step.
