Filter values below a threshold in influx
it seems a very simple request, but I am failing after more than one hour of searching forums and stackoverflow:
I have some outliers in my data. For that, I want to display only values below a certain threshold.
The query currently is
SELECT spread(“value”) FROM “Haustechnik.Stromzaehler.Zaehlerstand” WHERE $timeFilter GROUP BY time(1d) fill(null)
I have tried
SELECT spread(“value”) FROM “Haustechnik.Stromzaehler.Zaehlerstand” WHERE (“value” < 50) AND $timeFilter GROUP BY time(1d) fill(null)
But I understand that this filters out values < 50, whereas I want to filter out if the result of "spread(“value”) is smaller than 50.
I have also tried “INTO” but it seems that I do not understand the syntax.
Can you help me on this, please?
Regards,
Hendrik
Where spread(“value”)  < 50
Thanks for your reply.
I tried this:
SELECT spread(“value”) FROM “Haustechnik.Stromzaehler.Zaehlerstand” WHERE ($timeFilter AND spread(“value”) < 50) GROUP BY time(1d) fill(null)
But it lead to this error:
message:“InfluxDB Error: error parsing query: found “, expected identifier, string, number, bool at line 1, char 128”
Did I mis-understand?
Best regards,
Hendrik
Can someone help me on this, please?
SELECT spread("value") FROM "Haustechnik.Stromzaehler.Zaehlerstand" WHERE $timeFilter AND spread("value") < 50 GROUP BY time(1d) fill(null)
