nes3Ah
March 28, 2023, 12:23pm
1
Grafana v9.4.7
I query from an InfluxDB via Flux and want to get a single value.
But the bucket has 6 topics coming from MQTT to InfluxDB, and I didn’t manage to filter them out. I want only one of them to be in this query.
from(bucket: "solar")
|> range(start: -3h)
Can someone help me to add a filter to the code?
I tried a lot with google, but nothing worked.
The desired value is shown in the graph as following:
value {host="InfluxDB", topic="solar/12345/0/power"}
The data type is a float (Power in Watt of my solar panel inverter)
Thanks in advance
grant2
March 28, 2023, 12:27pm
2
@nes3Ah
Welcome to the Grafana forum.
Can you show the full Flux query and a table of the results, as viewed in Influx Data Explorer)?
Then in that screenshot, show us exactly what you want to extract / filter?
nes3Ah
March 28, 2023, 12:42pm
3
Hi grant2,
thanks for your reply.
My full query so far is
|> range(start: -3h)
The result looks the following:
As said, I’d like to query only the “…/0/power” value for this pattern.
Edit:
To say it, I just got in touch with MQTT, Telegraf, InfluxDB and Grafana a few days ago and spent some hours to get them working in LXCs on my ProxMox VE Homeserver
grant2
March 28, 2023, 1:05pm
4
Have you played around with the Data Explorer in Influx to build the query you desire?
For example, this:
is the same as this (viewable after clicking the “Script Editor” button) on the right:
from(bucket: "junkbucket")
|> filter(fn: (r) => r["_field"] == "PercentTotalCapacity")
|> filter(fn: (r) => r["EquipZone"] == "CircuitA")
|> filter(fn: (r) => r["EquipNumber"] == "32")
|> filter(fn: (r) => r["_measurement"] == "ChillerData")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: "mean")
nes3Ah
March 28, 2023, 1:15pm
5
Many thanks, now I understand how the filter in Grafana works!
I checked the data explorer in InfluxDB, adjusted your code and added it in Grafana:
|> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
|> filter(fn: (r) => r["_field"] == "value")
|> filter(fn: (r) => r["host"] == "InfluxDB")
|> filter(fn: (r) => r["topic"] == "solar/12345/0/power")
|> yield(name: "mean")
Works exactly as I wanted, now I will adapt this for the other values.
Thanks a lot and have a nice day!
grant2
March 28, 2023, 1:16pm
6
Great, glad it’s good now. In case you want to create alerts in Grafana using Flux, here is a tutorial from a few months ago.
how can i filter all the topics list. I want a quert that output all the topic in the topic filter. I just want list of topics
Currently i am using this query but its not working fine
from(bucket: “kimono-influxdb”)
|> range(start: -30d, stop: now())
|> filter(fn: (r) => r[“_measurement”] == “mqtt_consumer” or r[“_measurement”] == “mqtt_float” or r[“_measurement”] == “mqtt_json” or r[“_measurement”] == “mqtt_string”)
|> filter(fn: (r) => r[“host”] == “tcf-kimono-mqtt.th-deg.de ”)
|> filter(fn: (r) => r[“topic”] =~ /kimono/)
|> aggregateWindow(every: 1h, fn: (column, tables=<-) => tables |> last(column: column), createEmpty: false)
|> distinct(column: “topic”)
|> yield(name: “last”)
