Hello all.
I’ve tried adding the notification policies from helm using a mounted configmap. When I use the first method of directly putting the file in helm, it works properly.
alerting:
notifiaction-policies.yaml:
apiVersion: 1
policies:
- orgId: 1
receiver: testingtest
group_by: ['grafana','alertname']
However, when I use file, which is mounted using extraConfigmapMounts, the policy is not created, and in helm I get
notification-policies: "" as the value being read instead of the below:
alerting:
notification-policies.yaml:
file: alerting/shared/notification-policies.yaml
For reference, this is my extraConfigmapMounts configuration. I also verified that the file is mounted properly in the referenced directory.
extraConfigmapMounts:
- name: grafana-alerting-config-volume
mountPath: /var/lib/grafana/alerting/shared/
subPath: ""
configMap: grafana-alerting-config
readOnly: false
And the actual notification policy in the configmap, which is the same as the one above:
apiVersion: v1
data:
notification-policies.yaml: |-
apiVersion: 1
policies:
- orgId: 1
