Failed to send test alert, the receiver timed out
    V10.0.2
    I am trying to configure grafana to send alerts by mail using gmail on a new server.
    Using the same configuration I am have used for smtp on my old server on grafana V9.
  • What happened?
    I am always getting an error message: Failed to send test alert: the receiver timed out, failed to send notification to email addrees xx@xx.de, dial tcp [2a00:1450:4013:c1a::1b]:587 i/o timeout
    [smtp]
    enabled = true
    host = smtp.google.com:587
    user = xxx@gmail.com
    password = xxx
    ;cert_file =
    ;key_file =
    ;skip_verify = true
    from_address = xxx@gmail.com
    from_name = Grafana
    ;ehlo_identity = dashboard.example.com
    startTLS_policy = MandatoryStartTLS
    The above message is shown in the UI.
The gmail acoount is using 2FA and I have generated an app password for it. On my google security I can see, that this password so far has not been used. On the same server I am also running a sendmail configuration to the same gmail account and using sendmail I have no problems in sending a mail.
Looking forward for any help on this issue.
I had it running fine using these:
[smtp]
skip_verify = true
;startTLS_policy=
Hi, unfortunately this does not change anything.
