Fail( [err] ) the command stopped working
i had a few of fail( [err] ) in my script.
today they stopped working
import http from 'k6/http';
import { check, fail } from 'k6';
export default function () {
  const res = http.get('https://k6.io');
  if (
    !check(res, {
      'status code MUST be 200': (res) => res.status == 99999,
    fail('status code was *not* 99999');
getting a following messages on console
Hi @HardBoiledEG
I tried a similar script (I just had to change the status code as 99999 is not accepted in HTTP1.1):
    const res = http.get('https://httpbin.test.k6.io/status/999');
    //const res = http.get('https://k6.io/');
    if (
        !check(res, {
            'status code MUST be 200': (r) => r.status === 999,
        fail('status code was *not* 999');
This works well for me.
I find it a bit confusing that the check name is 'status code MUST be 200', while you check for 99999. However, as in my example, if the endpoint is returning a 999 (or 99999 for you), it should work. I would just change the check name to make the script clearer, 'status code MUST be 999':
    if (
        !check(res, {
            'status code MUST be 999': (r) => r.status === 999,
That said, when you say this stopped working, did you check if anything change in your SUT (System Under Test)?
I would suspect it’s not returning the status code you are checking for (be it 99999 - your script - or 9999 as your screenshot shows). I would check this with a curl command, similar to:
curl -X GET "https://httpbin.test.k6.io/status/999" -v
And make sure it’s returning the status code you are checking for in the test script. In my case it’s indeed HTTP/1.1 999 UNKNOWN:
< HTTP/1.1 999 UNKNOWN
< Date: Fri, 10 Mar 2023 14:01:31 GMT
< Content-Type: text/html; charset=utf-8
< Content-Length: 0
< Connection: keep-alive
< Access-Control-Allow-Origin: *
< Access-Control-Allow-Credentials: true
Let me know if that helps.
Cheers!
thanks for taking the time to answer.
Looks like, I did not explain the issue properly.
I need to fail the test if the Status !== 200
see following code
  let host_name;
  host_name = 'https://k6.io'; //STATUS 200 OK
  host_name = 'https://k6.io+++'; //STATUS is not 200
  const res = http.get(host_name);
  let api_code = 200;
  if (
    !check(res, {
      [`status code MUST be ${api_code}`]: (res) => res.status == api_code,
    fail(`status code was *not* ${api_code} - [${res.error}/ ${res.error_code}]`);
Hi @HardBoiledEG
This should be pretty straight forward from a check in the k6 documentation:
    //const res = http.get('https://httpbin.test.k6.io/status/403');
    const res = http.get('https://httpbin.test.k6.io/status/200');
    if (
        !check(res, {
            'status code MUST be 200': (r) => r.status === 200,
        fail('status code was *not* 200');
This works:
If you execute with the URL that returns, e.g., a 403, const res = http.get('https://httpbin.test.k6.io/status/403, it fails.
Depending on your needs you can even mix checks and thresholds: Thresholds.
import { check, sleep } from 'k6';
export const options = {
    vus: 50,
    duration: '10s',
    thresholds: {
        // the rate of successful checks should be higher than 90%
        checks: ['rate>0.9'],
    check(res, {
        'status is 200': (r) => r.status == 200,
    sleep(1);
I hope this helps.
Cheers!
@eyeveebe Thanks again.
However, u are getting the same issue as I am. A compilation error
ERRO[0000] GoError: status code was *not* 200 running at go.k6.io/k6/js/modules/k6.(*K6).Fail-fm (native)
As a result, the test is aborted.
My understanding, the fail shouldaAbord the current script iteration if a check fails fail the C
consider the following code
export function make_call(end_point){
  const res = http.get(end_point);
  if (
      !check(res, {
  let end_point;
  //end_point = http.get('https://httpbin.test.k6.io/status/200');
  end_point = http.get('https://httpbin.test.k6.io/status/403');
  console.log(`DONE`);// Last command
Then the make_call fails, the last command in default function is not executed
The script should not be aborded on fail
Hi @HardBoiledEG
In the example I was just executing an iteration, and it stopped. However, you can define a script with 1 VU, 10 iterations:
    vus: 1,
    iterations: 10,
    const res = http.get('https://httpbin.test.k6.io/status/404');
    if (
        !check(res, {
            'status code MUST be 200': (res) => res.status == 200,
And you will see the 10 errors.
Each iteration fails.
I hope this helps clarify the fail( [err] ) behavior.
I am so mad at meself. Just added following to a Calling function
try{
  catch{
and everything started making sense and working
Thanks, again.
  if (
      !check(res, {
  let end_point;
 try{
 catch(error){
     console.log(`${error}`);
