divinp
July 21, 2021, 2:38pm
1
can anyone help me in getting the below id captured in K6 script:
<div class="yCmsComponent js_nav__link">
<a href="/pe/ofertas/c/dest-06" title="Tester">Tester</a></div></div>
</li>
We have multiple values with the same boundary, I have to capture the value inside ahref and title , how we can do that and keep it in an array to use further.
imiric
July 23, 2021, 3:39pm
2
Hi, welcome to the forum
Take a look at the parseHTML() function .
You could use it like so:
import { parseHTML } from 'k6/html';
export default function () {
const content = `
</li>
// Make sure the selector is precise enough.
const sel = parseHTML(content).find('div > a'),
el = sel.get(0),
attrs = el.attributes();
console.log(attrs.href.value);
console.log(attrs.title.value);
Which when run outputs:
INFO[0000] /pe/ofertas/c/dest-06 source=console
INFO[0000] Tester source=console
Also, if you’re getting this HTML from a response, you can use Response.html() .
