Hi Team,
Find this article https://k6.io/docs/javascript-api/k6-http/response/#example
When I try with the below code to extract the value of the Location from the response header I’m getting undefined message.
res.headers.Location
The response contains the value
Is there any way to extract values through the response header?
PaulM
March 22, 2022, 11:16am
2
Hi @Gerard
Will this answer help you?
import { check } from 'k6';
import http from 'k6/http';
export default function () {
const res = http.get('https://k6.io');
console.log(res.headers['Content-Type']);
if(res.headers['Content-Type'] == 'text/html') {
console.log(true);
} else {
console.log(false);
check(res, {
'status is 200': (r) => r.status === 200,
Hi @PaulM ,
I tried your option but still, it says undefined.
Response with --http-debug
From the code
Output says
PaulM
March 22, 2022, 1:54pm
4
You can also try:
let myResourceURL = res.headers['Content-Type'];
console.log('Result: ' + myResourceURL);
check(res, {
In your code:
let myResourceURL = srchLightres.headers['Expect-Ct']; (Pay attention that **t**)
console.log('The resource url was' + myResourceURL)
@PaulM I used the template literals. But if I changed the way you suggest also it gets an undefined message.
and the Output again like
PaulM
March 22, 2022, 2:01pm
6
@Gerard Change headers name:
srchLightres.headers[‘Expect-Ct ’]; (Pay attention that t )
PaulM:
Expect-Ct
Thanks, @PaulM Good catch. When I changed it to Expect-ct it works fine.
But when I try to capture another header value it shows undefined.
Any Tips to overcome this issue.
PaulM
March 22, 2022, 3:16pm
8
@Gerard Now it’s difficult to say what’s the problem, but if we are using this loop:
for (const p in res.headers) {
if (res.headers.hasOwnProperty(p)) {
console.log(p + ' : ' + res.headers[p]);
And find headers Location then this variable will definitely appear here res.headers[‘Location’]
