Hi Team,
I have a script where some request Id is getting generated after request is created. Client wants me to extract those values and write into a file. I have extracted the value. can you guide me how to append those into a CSV/ text file.
Thanks,
namrata
Hi @namratanirjharini74 For k6 don’t support write output file using CSV/text. Maybe can done by external library or tools, Maybe use k6 Webpack and ArrayToCSV to save extracted value in array then convert into CSV file.
Welcome to the community forum
To add to what @Elibarick mentioned, k6 core does not yet support writing to files. You can follow the issue Provide a file storing API · Issue #3017 · grafana/k6 · GitHub, and
to help prioritize the implementation.
You’ll also find that using a node module with Webpack might not work. From the docs:
k6 is not NodeJS, nor is it a browser. Packages that rely on APIs provided by NodeJS, for instance, the os and fs modules, will not work in k6. The same goes for browser-specific APIs like the window object.
You can find a good explanation of why fs is not supported on Write data to file - #2 by imiric.
While this is not possible in k6 core, you can use a community extension like GitHub - avitalique/xk6-file: k6 extension for writing files to write to a file. And there are also alternatives to using an extension to send the data to Redis, or a database. If you don’t necessarily need a local file.
I hope this helps.
Cheers!
