Exporting windows logs using Loki
Hi, I’ve been trying to learn Loki/Alloy so I can monitor AD group membership changes, but I am now encountering some weird issues I can’t seem to grasp my head over.
This label seems to be the only thing that ever shows up, I’m not even sure how to add new filters/services here.
My Alloy successfully sends logs to my Grafana using OTLP but I just can’t seem to filter this thing…
This is my current config.alloy that seems to work and filter ‘Alloy’ events:
// Windows Server Metrics Configuration
prometheus.exporter.windows "default" {
  enabled_collectors = ["cpu","cs","logical_disk","net","os","service","system", "memory", "scheduled_task", "tcp"]
// Configure a prometheus.scrape component to collect windows metrics.
prometheus.scrape "example" {
  targets    = prometheus.exporter.windows.default.targets
  forward_to = [otelcol.receiver.prometheus.endpoint.receiver]
// Windows Server Logs Configuration
loki.source.windowsevent "application"  {
    eventlog_name = "Application"
    use_incoming_timestamp = true
    exclude_event_data = true
    forward_to = [loki.process.windows_eventlog.receiver]
    labels = {
       job = "windows_eventlog",
       instance = constants.hostname,
loki.source.windowsevent "security"  {
    eventlog_name = "Security"
    labels = {
loki.source.windowsevent "system"  {
    eventlog_name = "System"
    labels = {
loki.source.windowsevent "setup"  {
    eventlog_name = "Setup"
    labels = {
loki.process "windows_eventlog" {
  stage.template {
      source   = "message"
      template = `{{- $message := .Value -}}
                  {{- if eq $message "" -}}empty_message
                  {{- else if eq $message nil -}}empty_message
                  {{- else -}}{{- $message -}}{{- end -}}`
  stage.windowsevent {
      source = "message"
      overwrite_existing = true
  stage.labels {
      values = {
          channel = "",
  stage.drop {
      source = "source"
      value  = "Alloy"
      drop_counter_reason = "source_alloy"
  stage.timestamp {
      source      = "timeCreated"
      format      = "2025-02-27T17:45:00.0000000Z"
  forward_to = [otelcol.receiver.loki.endpoint.receiver]
// Prometheus receiver for scraping metrics from the prometheus exporter
otelcol.receiver.prometheus "endpoint" {
	output {
		metrics = [otelcol.exporter.otlphttp.endpoint.input]
// Loki receiver for scraping logs from the loki source
otelcol.receiver.loki "endpoint" {
	output {
		logs = [otelcol.exporter.otlphttp.endpoint.input]
// OpenTelemetry Collector receiver for scraping logs from the loki source
otelcol.exporter.otlphttp "endpoint" {
	client {
		endpoint = "http://10.20.31.14:4318"
		tls {
			insecure = true
			insecure_skip_verify = true
I just want to monitor some specific event ids and have the ability to label them properly :frowning:
I don’t use Windows, so I can’t tell you exactly what’s wrong. But couple of suggestions:
  1. In each of your source you should add one more label to differentiate between the type of event logs, for example:
    labels = {
       event_type = "System",    // something like this
  1. when troubleshooting, keep your process pipeline simple. Remove everything, and just forward from loki.process to your otelcol.receiver direclly, make sure logs are flowing, then start adding things.
Hi Tony, thanks for the reply and help.
I removed everything and it all seems fine.
My main issue is that I want to make custom labels for my Loki but it always puts service_name and unknown_source, I’ve read some documentation and posts about changing it but I can’t seem to figure it out.
Everything seems to talk about linux systems which is not the case here…
service_name is a required label (for compatibility with open telemetry). You can either set one yourself, or set app label (Loki will use app label to populate service_name), otherwise it’s set to unknown.
