Hi all,
I refer to the manual regarding InfluxDB and logs exploring: InfluxDB data source | Grafana documentation
In particular the section on " Querying and displaying log data from InfluxDB is available via Explore". It says:
Select the InfluxDB data source, change to Logs using the Metrics/Logs switcher, and then use the
Measurements/Fieldsbutton to display your logs.
Well, I cannot seem to find this switcher… see screenshot.
Any idea what is going on here?
I am using Grafana 7.1 and InfluxDBv2. So I am not using the beta plugin for the datasource - 7.1 supports InfluxDBv2 datasources.
Thanks
