Expect.js: describe: what is the best way to pass data between requests?
Hi! I need to fetch data from one request (from Response-object or array/list of Response-object in case of using batch method) and put that data into another request (into request body).
Suppose I have such scenario:
  describe(`02. POST /someMethod should return 200 OK and correct data`, (t) => {
    console.log('02. POST /someMethod:');
    let active_user = testdata[0]["user"]
    const randomUser = active_user[Math.floor(Math.random() * active_user.length)];
    console.log('Random user: ', JSON.stringify(randomUser));
    console.log(`02. POST someMethod: active_user: ${randomUser}`)
    session.addHeader("user", `${randomUser}`)
    session.addTags("POST-someMethod")
    let response = session.post("/someMethod",
    JSON.stringify({
        "field1": `${randomUser}`,
        "field2": "qwerty",
        "field3": "1234"
    t.expect(response.status).as("response status").toEqual(200)
    someId = response.json("someId");
    anotherId = response.json("map.anotherId");
  describe(`03. POST /someMethod2`, (t) => {
    console.log('03. POST /someMethod2:');
    // console.log('testdata: ', JSON.stringify(testdata));
    // Pick a random username/password pair
    console.log(`03. POST /someMethod2: active_user: ${randomUser}`)
    let someMethod2 = {
      method: "POST",
      url: `${__ENV.BASE_URL}/someMethod2`,
      body: JSON.stringify({
          "someId": `${someId}`,  // Here is the place where above values should be put
          "anotherId": `${anotherId}`,  // Here is the place where above values should be put
          "field3": "val"
      params: {headers: {"accept": "application/json",
                        "token": "sdfsdfssg",
                        "user": `${randomUser}`}}
    let responses = http.batch([someMethod2],
      tags: {my_tag: "POST-someMethod2"},
    responses.forEach(response => {
        .and(response).toHaveValidJson()
What is the best practice here? I just declare module vars in the init context like this:
export let someId;
export let anotherId;
Or there is a better way?
What about http.batch or session.batch responses? How to pass responses’ lists into next request?
P.S.: I know that expect.js deprecated and it is recommended to use ChaiJS lib, but, unfortunately, we don’t have much time to migrate current old code…
I am not sure there are much better way than this, sorry. Maybe encapsulating the the calls you expect a value from in a separate function that returns these values as its result? That seems a bit cleaner, but might be a bit over-complicated or have issues of its own, I don’t know your use case.
I don’t understand the question, sorry. The result of http.batch() is just an array (or object, if you used object as its parameter) with all of the responses, so you can use that?
