Hey folks, been searching and not coming up with anything positive and found this, so figured I would ask here.
My team has some legacy UI automation written using Cucumber (with feature files) on TS with Playwright.
I can transpile the TS to JS easily enough, and changing from Playwright to K6 browser is simple enough, but I haven’t found a way to launch the automation using K6 for UI performance testing.
So my questions are:
- Is it a supported configuration?
- If it is, what’s the magic sauce to connect the pieces?
I’ve searched online, and the only answers I’ve found are negative (and that includes StackOverflow).
I’m currently porting the automation away from Cucumber, but it would be really great if I didn’t have to.
Thanks!
