OSS v10.3.1 - What are you trying to achieve?
Create a graph to have the mean (average data) of all non 0 values - How are you trying to achieve it?
built in function of settings for graphs: calculation → “mean”
I tried to set a minimum value of 0.1; still not helped. - What happened?
it also calculates 0 values as well. - What did you expect to happen?
I’d like help to exclude the 0 values. - Can you copy/paste the configuration(s) that you are having problems with?
N/A - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
N/A - Did you follow any online instructions? If so, what is the URL?
N/A - only tried to give in a minimum axes value, but didn’t help.
try the filter data by values transformation
Thanks, that is indeed a workaround - but on a very busy dashboard it would be nice not to loose the visualization of 0 values while still having the “correct” calculation.
If there is no solution indeed it is working, it can be space for improvement to have an option checkbox “exlude 0”.
what ia your data source
