I have placed the plugin under var/lib/grafana/plugins/ in grafana docker instance and it is displayed “installed” in the web UI plugin catlog, but when I try to add that new panel, an error “Error loading: natel-plotly-panel” in a red bar.
Welcome @andyxcola
Check another way to do plotly
@yosiasz
sadly, I can’t install any plugin with grafana-cli(due to my company’s internet policy) so i want to install plugin locally
But the error mentioned above occurred when i add any plugin locally
Hi @andyxcola
What assets did you put inside this folder? source code? extracted contents of the plugin archive?
