Error installing Loki in GKE cluster
evel=info ts=2024-10-29T08:35:52.849265693Z caller=main.go:126 msg="Starting Loki" version="(version=k218-659f542, branch=k218, revision=659f5421)"
level=info ts=2024-10-29T08:35:52.849357685Z caller=main.go:127 msg="Loading configuration file" filename=/etc/loki/config/config.yaml
level=info ts=2024-10-29T08:35:52.860956016Z caller=server.go:351 msg="server listening on addresses" http=[::]:3100 grpc=[::]:9095
level=info ts=2024-10-29T08:35:52.863388198Z caller=memberlist_client.go:439 msg="Using memberlist cluster label and node name" cluster_label= node=loki-backend-1-1c87edb8
level=info ts=2024-10-29T08:35:52.87390041Z caller=table_manager.go:280 index-store=tsdb-2024-04-01 msg="query readiness setup completed" duration=5.546µs distinct_users_len=0 distinct_users=
level=info ts=2024-10-29T08:35:52.874000981Z caller=shipper.go:160 index-store=tsdb-2024-04-01 msg="starting index shipper in RO mode"
level=info ts=2024-10-29T08:35:52.885149875Z caller=mapper.go:47 msg="cleaning up mapped rules directory" path=/var/loki/rules-temp
level=info ts=2024-10-29T08:35:52.892723198Z caller=module_service.go:82 msg=starting module=runtime-config
level=info ts=2024-10-29T08:35:52.892816827Z caller=module_service.go:82 msg=starting module=analytics
level=info ts=2024-10-29T08:35:52.893017137Z caller=module_service.go:82 msg=starting module=server
level=info ts=2024-10-29T08:35:52.893084329Z caller=module_service.go:82 msg=starting module=memberlist-kv
level=error ts=2024-10-29T08:35:52.893197467Z caller=loki.go:560 msg="module failed" module=memberlist-kv error="starting module memberlist-kv: invalid service state: Failed, expected: Running, failure: service memberlist_kv failed: failed to create memberlist: Failed to get final advertise address: no private IP address found, and explicit IP not provided"
level=error ts=2024-10-29T08:35:52.893355879Z caller=loki.go:560 msg="module failed" module=compactor error="failed to start compactor, because it depends on module analytics, which has failed: context canceled"
level=error ts=2024-10-29T08:35:52.893400256Z caller=loki.go:560 msg="module failed" module=ingester-querier error="failed to start ingester-querier, because it depends on module memberlist-kv, which has failed: invalid service state: Failed, expected: Running, failure: starting module memberlist-kv: invalid service state: Failed, expected: Running, failure: service memberlist_kv failed: failed to create memberlist: Failed to get final advertise address: no private IP address found, and explicit IP not provided"
level=error ts=2024-10-29T08:35:52.893425287Z caller=loki.go:560 msg="module failed" module=index-gateway-ring error="failed to start index-gateway-ring, because it depends on module memberlist-kv, which has failed: invalid service state: Failed, expected: Running, failure: starting module memberlist-kv: invalid service state: Failed, expected: Running, failure: service memberlist_kv failed: failed to create memberlist: Failed to get final advertise address: no private IP address found, and explicit IP not provided"
level=error ts=2024-10-29T08:35:52.893446397Z caller=loki.go:560 msg="module failed" module=query-scheduler-ring error="failed to start query-scheduler-ring, because it depends on module memberlist-kv, which has failed: invalid service state: Failed, expected: Running, failure: starting module memberlist-kv: invalid service state: Failed, expected: Running, failure: service memberlist_kv failed: failed to create memberlist: Failed to get final advertise address: no private IP address found, and explicit IP not provided"
level=error ts=2024-10-29T08:35:52.893468073Z caller=loki.go:560 msg="module failed" module=ring error="failed to start ring, because it depends on module memberlist-kv, which has failed: invalid service state: Failed, expected: Running, failure: starting module memberlist-kv: invalid service state: Failed, expected: Running, failure: service memberlist_kv failed: failed to create memberlist: Failed to get final advertise address: no private IP address found, and explicit IP not provided"
level=error ts=2024-10-29T08:35:52.893496194Z caller=loki.go:560 msg="module failed" module=store error="failed to start store, because it depends on module memberlist-kv, which has failed: invalid service state: Failed, expected: Running, failure: starting module memberlist-kv: invalid service state: Failed, expected: Running, failure: service memberlist_kv failed: failed to create memberlist: Failed to get final advertise address: no private IP address found, and explicit IP not provided"
level=error ts=2024-10-29T08:35:52.8935126Z caller=loki.go:560 msg="module failed" module=index-gateway error="failed to start index-gateway, because it depends on module store, which has failed: context canceled"
level=error ts=2024-10-29T08:35:52.893529369Z caller=loki.go:560 msg="module failed" module=ruler error="failed to start ruler, because it depends on module store, which has failed: context canceled"
level=error ts=2024-10-29T08:35:52.893641984Z caller=loki.go:560 msg="module failed" module=query-scheduler error="failed to start query-scheduler, because it depends on module analytics, which has failed: context canceled"
level=info ts=2024-10-29T08:35:52.8937371Z caller=module_service.go:120 msg="module stopped" module=runtime-config
level=info ts=2024-10-29T08:35:52.893968046Z caller=module_service.go:120 msg="module stopped" module=analytics
level=info ts=2024-10-29T08:35:52.895598648Z caller=modules.go:2054 msg="server stopped"
level=info ts=2024-10-29T08:35:52.895630687Z caller=module_service.go:120 msg="module stopped" module=server
level=info ts=2024-10-29T08:35:52.895653492Z caller=loki.go:544 msg="Loki stopped" running_time=62.133868ms
failed services
github.com/grafana/loki/v3/pkg/loki.(*Loki).Run
/src/loki/pkg/loki/loki.go:602
main.main
/src/loki/cmd/loki/main.go:129
runtime.main
/usr/local/go/src/runtime/proc.go:271
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1695
level=error ts=2024-10-29T08:35:52.895758522Z caller=log.go:216 msg="error running loki" err="failed services\ngithub.com/grafana/loki/v3/pkg/loki.(*Loki).Run\n\t/src/loki/pkg/loki/loki.go:602\nmain.main\n\t/src/loki/cmd/loki/main.go:129\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:271\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1695"
