urmit
May 8, 2023, 2:30pm
1
I’m having trouble getting a browser test to work. I am running k6 through Docker and have the following Dockerfile:
FROM grafana/k6:latest
USER root
RUN apk update && apk add --no-cache chromium
ENV K6_BROWSER_ENABLED=true
ENV LOAD_TEST_TARGET_VU_COUNT=1
ENV LOAD_TEST_SECRET_SEED=1
Here is my test script:
import { sleep, check } from "k6";
import { Rate } from "k6/metrics";
import { chromium } from "k6/experimental/browser";
export const errorRate = new Rate("errors");
export default async function () {
const browser = chromium.launch({
args: ["no-sandbox"],
ignoreDefaultArgs: ["enable-automation"],
headless: true,
timeout: "60s", // Or whatever time you want to define
console.log("🚀launching browser");
// I've tried using an explicit context resulting in a similar error
// const context = browser.newContext();
// // const page = context.newPage();
const page = browser.newPage();
console.log("✨new page");
try {
await page.goto("https://somepage.com/login");
let submitButton = page.locator('input[type="submit"]');
} finally {
page.screenshot({ path: "screenshot.png" });
page.close();
browser.close();
check(true, {
"status is 200": () => true,
}) || errorRate.add(1);
sleep(1);
How I build and run the image:
docker build -t browser-k6 -f ./load-test/Dockerfile .
docker run --rm --network="host" -i browser-k6 run - <./load-test/src/test.js
Error:
time="2023-05-08T14:19:04Z" level=error msg="communicating with browser: websocket: close 1006 (abnormal closure): unexpected EOF" category=cdp elapsed="0 ms" goroutine=56
time="2023-05-08T14:19:04Z" level=error msg="process with PID 17 unexpectedly ended: signal: trace/breakpoint trap" category=browser elapsed="6 ms" goroutine=86
time="2023-05-08T14:19:04Z" level=error msg="Uncaught (in promise) GoError: creating new page in browser context: canceled\n\tat github.com/grafana/xk6-browser/browser.mapBrowser.func3 (native)\n\tat file:///-:49:15(26)\n" executor=per-vu-iterations scenario=default
Error when using explicit context:
time="2023-05-08T14:30:00Z" level=error msg="communicating with browser: read tcp 127.0.0.1:57700->127.0.0.1:33765: read: connection reset by peer" category=cdp elapsed="0 ms" goroutine=82
time="2023-05-08T14:30:00Z" level=error msg="process with PID 17 unexpectedly ended: signal: trace/breakpoint trap" category=browser elapsed="5 ms" goroutine=70
time="2023-05-08T14:30:00Z" level=error msg="Uncaught (in promise) GoError: creating new page in browser context: creating a new blank page: read tcp 127.0.0.1:57700->127.0.0.1:33765: read: connection reset by peer\n\tat github.com/grafana/xk6-browser/browser.mapBrowserContext.func4 (native)\n\tat file:///-:48:15(30)\n" executor=per-vu-iterations scenario=default
I’m enjoying using k6, thank you for all your hard work on the library and community. Thank you also for your help ahead of time.
ankur
May 8, 2023, 3:43pm
2
Hi @urmit ,
Welcome to the forum
Are you running this on an M series Apple computer (ARM architecture)? I’ve ran into the same issue on my Mac. grafana/k6:latest image is currently only built for amd64.
This dockerfile (which is part of the xk6-browser repo) works for me:
FROM golang:1.19-bullseye as builder
RUN go install -trimpath go.k6.io/xk6/cmd/xk6@latest
RUN xk6 build --output "/tmp/k6" --with github.com/grafana/xk6-browser
FROM debian:bullseye
RUN apt-get update && \
apt-get install -y chromium
COPY --from=builder /tmp/k6 /usr/bin/k6
ENV XK6_HEADLESS=true
ENTRYPOINT ["k6"]
Let me know if that works for you or not.
Cheers,
Ankur
urmit
May 10, 2023, 8:44pm
3
Hey @ankur ,
Thanks for your quick response. This was a huge help and it works great
Hi all!
Thanks so much for being active in the k6 forum and I love the capabilities you provide us in testing!
Was having the same problem as well, in Apple M1.
Script (from the sample docs)
(have a setup script to extract test data from a source)
export default async function (data?: any) {
if (!data) return;
args: ['no-sandbox'],
headless: true,
timeout: '10m',
slowMo: '100ms'
const context = browser.newContext({
userAgent: 'k6/custom-userAgent AppleWebKit '
try {
await page.goto(data.url, { waitUntil: 'networkidle' });
page.locator('input[name="login"]').type(data.username);
page.locator('input[name="password"]').type(data.password);
const submitButton = page.locator('input[type="submit"]');
await Promise.all([page.waitForNavigation(), submitButton.click()]);
check(page, {
header: page.locator('h2').textContent() == 'Welcome, admin!'
} finally {
page.close();
browser.close();
Dockerfile:
FROM golang:1.20.3-bullseye as builder
RUN .....
RUN go install -trimpath go.k6.io/xk6/cmd/xk6@v0.9.1
FROM alpine:3.17
COPY additional-ca-certs.crt /root/additional-ca-certs.crt
COPY additional-ca-certs.crt /usr/local/share/ca-certificates/additional-ca-certs.crt
RUN cat /root/additional-ca-certs.crt >> /etc/ssl/certs/ca-certificates.crt
RUN apk update && \
apk --no-cache add ca-certificates curl && \
apk --no-cache add gnupg && \
apk --no-cache add chromium && \
update-ca-certificates && \
rm -rf /tmp/* /var/cache/apk/*
RUN adduser -D -u .... -g .... k6
WORKDIR /home/k6
USER k6
ENV RUN_IN_CONTAINER="True"
ENTRYPOINT ["/usr/bin/timeout", "15m", "./entrypoint.sh"]
To run this:
docker run -it --rm --platform linux/arm64 --env-file ./.env.local k6-platform:latest
But i get the error:
INFO[0004] k6_basic https://test.k6.io/my_messages.php admin *** source=console
ERRO[0037] communicating with browser: read tcp 127.0.0.1:35342->127.0.0.1:45547: read: connection reset by peer category=cdp elapsed="0 ms" goroutine=78
ERRO[0037] Uncaught (in promise) GoError: internal error while removing binding from page: websocket: close 1001 (going away)
running at github.com/grafana/xk6-browser/api.Page.Close-fm (native)
k6_basicat _callee$ (webpack://@cmctechnology/stockbroking-automation-k6-platforms/./src/tests/basic/k6Basic.test.ts:58:15(166))
at call (native)
at tryCatch (webpack://@cmctechnology/stockbroking-automation-k6-platforms/./src/tests/basic/k6Basic.test.ts:2:0(9))
at webpack://@cmctechnology/stockbroking-automation-k6-platforms/./src/tests/basic/k6Basic.test.ts:2:0(101)
at webpack://@cmctechnology/stockbroking-automation-k6-platforms/./src/tests/basic/k6Basic.test.ts:2:0(5)
at asyncGeneratorStep (webpack://@cmctechnology/stockbroking-automation-k6-platforms/./src/tests/basic/k6Basic.test.ts:2:0(6))
at _next (webpack://@cmctechnology/stockbroking-automation-k6-platforms/./src/tests/basic/k6Basic.test.ts:2:0(10)) executor=per-vu-iterations scenario=k6_basic
ERRO[0037] process with PID 22 unexpectedly ended: signal: killed category=browser elapsed="5 ms" goroutine=72
The script works on
my local M1
the docker image works in my colleague’s apple intel i9
so seems to be the arm architecture that’s giving us trouble this time.
Hi @icedlatte ,
This seems like a bug Could you please create an issue about this on our Github? Thanks!
ankur
June 19, 2023, 2:03pm
8
Hi @icedlatte ,
Have you tried working with debian instead of alpine? I’ve found that working with debian gets me better results when working on M1 Macs.
Cheers,
Ankur
hello all, thank you so much for the guidance!
We managed to get things to work with alpine for M1, running it as:
docker run -it --rm --platform linux/arm64 ...
we also found that our firewall contributes to these issues we’re facing with M1, and we managed to work around that as well.
Cheers!
