hello,
connects to the DB but does not show the DBs
I use zabbix + grafana v10.3.3 (ubuntu 22)
and I’m trying to connect to postgres 14 (ubuntu 22),
I’m having problems connecting to a postgres base, not just one, but the 3 different servers. I can add it in datasource → add new → postgres… I add the connection data and test OK (msg in green OK) But in explore data → it doesn’t show the table, it says it’s connected but it doesn’t load the tables .
I’ve already tested the login and password connected via dbeaver and heidisql and connecting normally and I can do select.
follow the print
com conexao mysql funciona perfeitamente.
TY
