ERRO[0000] TypeError: Object has no member 'launch'
I am getting the below error while running a simple sample script.
        at file:///Users/afsalbacker/Desktop/k6/browser.js:4:34(8)
        at native  executor=per-vu-iterations scenario=default source=stacktrace
My code is:
import launcher from ‘k6/x/browser’;
export default function () {
  const browser = launcher.launch('chromium',{ headless: false });
  const context = browser.newContext();
  const page = context.newPage();
  page.goto('https://ecommerce.k6.io', { waitUntil: 'networkidle' })
My browser does not load because of this.
s
Hi @gm4afsal,
Welcome to the forums!
It looks like you are using a newer version of xk6-browser which contains a breaking change where the imports have changed.
Which version of xk6-browser are you running or what commands did you run to build a binary?
For the latest release of xk6-browser, this script should work:
import { chromium } from 'k6/x/browser';
  const browser = chromium.launch({ headless: false });
  page.goto('https://test.k6.io', { waitUntil: 'networkidle' })
  .finally(() => {
    page.close();
    browser.close();
Cheers,
Ankur
Hi @ankur
i see the below issue after the k6 upgrade to latest version:
ERRO[0000] Uncaught (in promise) TypeError: Cannot read property 'launch' of undefined or null
code I am using is:
Hi @santosh,
Can you please give us the following details:
  1. The full script.
  2. The version of k6 you are working with.
A guess is that you are working with a newer version of k6 (v0.46.0+) where the API has changed. There is a migrations guide on how to migrate your test scripts to v0.46.0 of k6: Migrating to k6 v0.46
Cheers,
Ankur
