Hi
We are ingesting logs from Fluentd to loki and loki is running on K8 enviroment with replication value 3 .
We are getting the below error - err="rpc error: code = 2022-07-21T21:04:36.428474528+02:00 level=warn ts=2022-07-21T19:04:36.428343978Z caller=grpc_logging.go:38 method=/logproto.Pusher/Push duration=145.357µs err=“rpc error: code = Code(400) desc = entry with timestamp 2022-07-18 07:26:08.685550897 +0000 UTC ignored, reason: ‘entry too far behind’ for stream: {container="XXXXXX", env="XXXXXXX", fluentd_thread="flush_thread_1", namespace="kube-system", pod="XXXXXXXX"},\nentry with timestamp 2022-07-18 07:26:59.909540823 +0000 UTC ignored, reason: ‘entry too far behind’ for stream: {container="cXXXXXX", env="XXXXXX", fluentd_thread="flush_thread_1", namespace="kube-system", pod="XXXXXXX"},\ntotal ignored: 2 out of 2” .
Please any suggestions would be very helpful .
I have seen here that loki accepts out of order entries by default and depends on max_chunk_age value. Any inputs would be really helpfull.
----- As per loki config documentation --------------
How far into the past accepted out-of-order log entries may be is configurable with max_chunk_age. max_chunk_age defaults to 1 hour. Loki calculates the earliest time that out-of-order entries may have and be accepted with
time_of_most_recent_line - (max_chunk_age/2)
Log entries with timestamps that are after this earliest time are accepted. Log entries further back in time return an out-of-order error.
Our Loki config file -
loki:
– Config file contents for Loki
@default – See values.yaml
config: |
auth_enabled: [% loki_config.auth_enabled %]
target: all,table-manager
server:
http_listen_port: [% loki_config.http_listen_port %]
grpc_server_max_recv_msg_size: 104857600
grpc_server_max_send_msg_size: 16777216
distributor:
ring:
kvstore:
store: memberlist
memberlist:
join_members:
- {{ include "loki.fullname" . }}-memberlist
ingester:
# Disable chunk transfer which is not possible with statefulsets
# and unnecessary for boltdb-shipper
max_transfer_retries: 0
chunk_idle_period: 1h
chunk_target_size: 1536000
max_chunk_age: 8h
lifecycler:
join_after: 1s
ring:
kvstore:
store: memberlist
replication_factor: 1
wal:
enabled: false
ingester_client:
grpc_client_config:
query_scheduler:
max_outstanding_requests_per_tenant: 2048
grpc_client_config:
query_range:
parallelise_shardable_queries: false
limits_config:
enforce_metric_name: false
reject_old_samples: true
max_cache_freshness_per_query: 10m
max_query_lookback: 2352h
schema_config:
configs:
{% if loki_cassandra.enabled %}
store: cassandra
object_store: cassandra
schema: v11
index:
prefix: [% loki_cassandra.index.prefix %]
period: [% loki_cassandra.index.period %]
chunks:
prefix: [% loki_cassandra.chunks.prefix %]
period: [% loki_cassandra.chunks.period %]
{% endif %}
store: boltdb-shipper
object_store: aws
schema: v11
index:
prefix: loki_index_
period: 24h
storage_config:
boltdb_shipper:
shared_store: s3
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 168h
aws:
# Note: use a fully qualified domain name, like localhost.
# full example: http://loki:supersecret@localhost.:9000
s3: "[% loki_minio.connection_string %]"
s3forcepathstyle: true
http_config:
insecure_skip_verify: true
index_queries_cache_config:
memcached:
batch_size: 100
parallelism: 100
memcached_client:
consistent_hash: true
host: {{ include "loki.memcachedIndexQueriesFullname" . }}
service: http
cassandra:
auth: true
username: [% loki_cassandra.username %]
password: [% loki_cassandra.password %]
addresses: [% loki_cassandra.addresses %]
keyspace: [% loki_cassandra.keyspace %]
consistency: [% loki_cassandra.consistency %]
{% endif %}
chunk_store_config:
max_look_back_period: 2352h
table_manager:
chunk_tables_provisioning:
inactive_read_throughput: 0
inactive_write_throughput: 0
provisioned_read_throughput: 0
provisioned_write_throughput: 0
index_tables_provisioning:
retention_deletes_enabled: true
retention_period: 2352h
query_range:
align_queries_with_step: true
max_retries: 5
split_queries_by_interval: 15m
cache_results: true
results_cache:
cache:
memcached_client:
host: {{ include "loki.memcachedFrontendFullname" . }}
max_idle_conns: 16
service: http
timeout: 500ms
update_interval: 1m
query_scheduler:
grpc_client_config:
frontend_worker:
frontend_address: {{ include "loki.queryFrontendFullname" . }}:9095
grpc_client_config:
frontend:
log_queries_longer_than: 5s
compress_responses: true
tail_proxy_url: http://{{ include "loki.querierFullname" . }}:3100
compactor:
shared_store: s3
