Elasticsearch : usage of runtime fields in Grafana
    V9.4.1 on linux
    I defined some runtime fields in an elasticsearch index, and I would like to query them in a dashboard panel.
    I tried to use them in metrics or group by clauses, but the fields don’t appear in the list.
  • What happened?
    Nothing, the fields are not present.
    I expect the fields to be present in the list or a way to request them.
    This one explains the concept of runtime fields :
    Runtime fields context | Painless Scripting Language [8.6] | Elastic
having the same problem. runtime fields or scripted fields don’t seem to pop up in grafana when I’m using elasticsearch as a data source
I opened an issue and a (not finished) pull request for this feature here: Support querying of runtime fields from Elasticsearch data sources · Issue #96028 · grafana/grafana · GitHub
