Hi all!
I’m on Grafana 9.15 and I try to achieve if possibile a dynamic sql server connection (as data source). I would like to have a combo box (a variable with some custom values) for dinamicall change my data suorce.
I don’t know if is possibile… 'cause I don’t see any variable in the data source definition panel for SQL SERVER.
Would I like to get a dynamic change of the connection to the db? Is this possible?
Or do I necessarily have to create “X” data sources to SQL SERVER and then duplicate my dashboard by changing the connection in the panels?
How can I resolve this resource change without having to duplicate my dashboard? I would like it to be handled as a string by my selection menu (a variable) I don’t quite understand the purpose of “data source” type variables.
Alen
