I am new to K6 , I have query →
I have a CSV file where each row in CSV file will correspond to one testcase ,i.e. When i Iterate through CSV i will replace the data of each row in my API request and exceute the test.
Row 1 from CSV → XXX data populated in API and test executed
Row 2 from CSV-> XXX data populated in API and test executed
This is how jmeter works with CSV configurator.
My query is How can i Dynamically generate Scenarios to perform this in K6.
I tried as below →
Created Parent Script where i can loop through CSV and called Child script default function in it where in For every row i can run and verify the test.
But when i run the parentScript , output only shows 1 scenario executed as for child script default function its not considering a separate scenario.
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
INFO[0001] set up one source=console
INFO[0001] set up two source=console
INFO[0001] hiii admin source=console
INFO[0002] hiii admin source=console
Please advice how can we achieve this in K6, it similar to a DataProvider tests in testNG or CSVconfig in Jmeter.
Regards
Rajinder
Hi @9779012177, welcome to the community forum!
I do not understand both what you are trying to do and what isn’t working for you.
Can you provide a script example showcasing what you’ve done - you can omit any business logic and just point out where you want a line from the csv (for example).
You might also be interested in the example on how parameterize with csv and the general scenarios documentation.
Hi ,
So here is the script if you see below →
- parse CSV
- Open Request having templates which is to replaced for e.g → $username here username will be replaced with username key in CSV
- Scenario will loop for every row in CSV i.e. 1 row in csv holds input and out data for one testcase
Question is → Can we dynamically create scenario , such that Scenario name is the name of testcase which will be pulled from CSV ?
Some thing like below →
Loop CSV {
Create Dynamic scenario , iterate it one for every row of CSV data
SAMPLE Script - >
//CSV parsed
const csvData = papaparse.parse(open('users.csv'), { header: true }).data;
var request = open('./request.xml'); - //request template opened
//scenario being iterated for all rows in CSV
export const options = {
scenarios: {
'send_medication': {
executor: 'shared-iterations',
vus: 1,
iterations: csvData.length,
maxDuration: '1h',
export default function () {
business logic
export function handleSummary(data) {
return {
"summary.html": htmlReport(data),
Looking at this it seems you want to basically do the same as this example from the docs.
But replace it in xml instead of just logging the ${user}.
I have no idea what kind of template you have but you should be able to do the replace with some basic string manipulation.
Is there a particular thing that is unclear from the linked example?
