Hello and TIA!
Sorry if this gets asked and answered. I did my best to search, and I have a technical/math background. But I’m failing to figure this out.
v10.4.1. I’m using the Home Assistant add on (which is a docker container
zoo
- What are you trying to achieve?
I’m trying to inspect how much my furnace has been running in different conditions during the winter, specifically on the worst winter nights.
I am about to go searching for a replacement furnace/heat pump and I would like to know if/how much my current furnace is over spec’ed. I have been recording the state of my thermostat into a boolean “heating” variable for 18 months or so.
A typical on/off cycle is on for 30-50mins and off for 50-150mins. I’m mostly interested in the coldest nights.
I’d like to zoom into a particularly cold night and get several measurements that represent the duty cycle for the night. A period of 3hours or so, with the amount of time “on” in those 3 hours, plotted during the night, sampled every 10mins or so would be great.
Example data from the last 10 days in home assistant:
(The large “on” period is a bug. The power went out for 14 hours and it was “on” when we lost power, and then “on” again after we got power back).
- How are you trying to achieve it? & What happened?
This is as far as I’ve gotten. This is similar to what I have in home assistant except:
- It is only sampled on the 10 minute marks.
- The unknown state is represented as the previous. I think this is ok. It usually means that my thermostat isn’t publishing when it is off for a long time.
I don’t know how to get the select/group stuff to show anything like a duty cycle. I don’t know how to compute a duty cycle every 10 mins for the amount of time on over the last 3 hours.
N/A - Can you copy/paste the configuration(s) that you are having problems with?
See screenshot. - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
None - Did you follow any online instructions? If so, what is the URL?
None
