Duplicate log lines
I seem to be getting 2-4 duplicates of each log line in grafana UI. Not sure what is the cause. This was not the case before.
  1. What do you mean by “log lines in Grafana UI”?
I regard the Grafana UI as the web interface for dashboards, but you don’t get
log lines there, so where are you referring to?
  1. “This was not the case before” - before what?
Antony.
Sorry this was not clear, my bad.
I was referring to hosted logs solution offered by Grafana cloud via Loki.
From the Grafana UI, one can view and explore the logs.
The issue is that the same logs are getting displayed 2 or 4 times. This was not happening before
Did you ever resolve this issue? I am now experiencing log duplication as well. I believe it is due to how I configured the scrape_config
