Grafana version: 9.5.1 and its used in windows/ubuntu
- What are you trying to achieve?
I have a value which is stored in seconds and it is converted to time unit(dtdhms) so the format is like 24 d 01:01:20 and i want to colour based on that day range. So my example is if it goes between 0-14 i want to show orange.
I am using cloudwatch metrics.
- How are you trying to achieve it?
I have tried using value mappings regex and also range.
- What happened?
This doesnt work and no change. it always shows green no matter what day it has
