I’m trying to extract labels from log lines using regex. I wish stage.regex
had an option to drop lines which don’t match, but since it doesn’t, I’m trying to do this with a stage.match
block. Not sure why this isn’t working.
loki.process "filter_dante_controller" {
stage.regex {
expression = `^.* (?P<epoch_time>\d+) +(?P<level>\w+) +(?P<message>.*)$`
stage.match {
selector = `{epoch_time!~".*"}`
action = "drop"
stage.timestamp {
source = "epoch_time"
format = "UnixMs"
stage.output {
source = "message"
forward_to = [loki.write.grafanacloud.receiver]
Couple of things:
will literally match everything, including empty string.
- You don’t have to drop the logs if you don’t want to. You can set timestamp only of epoch_time is not empty, and for the rest of logs it’ll just get sent to Loki with timestamp as ingestion time.
If you want to drop, try this:
stage.regex {
stage.drop {
expression = `.+`
action = "drop"
stage.timestamp {
format = "UnixMs"
stage.output {
source = "message"
Thanks for your suggestion. Changing *
to +
fixed my issue.
Your code actually doesn’t work because action
is not valid in the stage.drop
. But I did it like this:
stage.match {
selector = `{epoch_time!~".+"}`
action = "drop"
