Is there some way to achieve this? It would be nice to be able to make some patterns for urls, like I log in to some certain page, but then id in the query string could be diffferent, so it would be more convenient to just use some general patterns like this.
Another thing is that k6 browser doesn’t seem to pick up urls for thresholds unless You use these urls in actions like await page.goto(url) or await page.reload(), are there any plans to maybe extend this thresholds measurments for redirects from page to page, without explicitly calling those page with page.goto or page.reload?
I think these are interesting points, let’s address them individually.
About the pattern matching on URL label for threshold. I think this can be an interesting feature, but this would most probably have to be supported “generically” in all metric labels.
This is more related with k6 core, so could you please write this specific part of the question in the k6 OSS forum? Or even create a Github issue for the feature request if you want. The k6 core team will address them from there.
As an alternative for your use case without requiring the pattern mathcing, we have this issue open in k6 browser which would allow labeling specific page.goto() actions, which could be used when defining the thresholds. Do you think this would fulfill your use case?
About thresholds only for the URLS used in page.goto() or page.reload(). This should not be the case. Web Vitals metrics should be measured on every loaded page. So for example, if you go to a site that returns a redirect to URL_X, there should be metrics associated for URL_X at the end of the test.
Are you experiencing different behavior? Could you provide us more details on this, or an example of a test that we can run?
I’m sorry to wake up this thread but I still can’t find a solution for this case. I’m trying to load an url (account overview) accessible from the main meny on the main overview page. Everytime I navigate to the url a new unique id is appended to the url (like this example: https://mydomain.se/account/overview/?id=jhkhkhj7676u786jy. This makes it impossible for me to measure the web vitals for the particular url https://mydomain.se/account/overview/ because when I define the threshold like this:
I believe this is now possible. I played around with page.on('metric') which I think resulted in what you’re asking for. What needs to happen is that the dynamic (high cardinality) URLs need to be grouped with a new tag name.
In the example below, I am navigating to https://quickpizza.grafana.com/?q=abc123 and https://quickpizza.grafana.com/?q=def456. The page.on event handler matches on the URLs with the regexp /^https:\/\/quickpizza\.grafana\.com\/\?q=[0-9a-z]+$/. When a match is found the url metric is retagged to test (both the name and url metric fields are replaced). Now i can define a threshold with the name of the new tag test like so 'browser_web_vital_fcp{name:test}': ['p(90) < 2000'].
Here’s my test script that you should be able to run:
Sorry for waking this thread up again but I wonder how to use a variable in the url matching in the page.on syntax. Like this (just an example because the syntax below with variable myTestEnvironment does not work)
I don’t know what “delimiter” to use to extract the value of myTestEnvironment (for example {myTestEnvironment} or <myTestEnvironment> or alike). I hope you understand what I mean.
Really appreciate some help because now I can only use a static value for the test environment in the url like this: {url: /^https:\/\/test\.uat\.mydomain\.se\/account\/overview\/\?id\=[a-zA-Z0-9_]+$/}
