I have a Loki cluster. I set up the cluster initially with persistent volumes (via CSI) so that if any instances needed to be restarted (or removed/added) they would have the same persistent storage. This worked great. I have since updated the cluster to use remote object storage. Now I am wondering if I need to keep the persistent volumes for anything.
I was reading through the TSDB documentation and see that Index Caching is not required.
This is how the persistent volume looks on one the instances in my cluster:
loki/
chunks/ (empty)
compactor/ (empty)
index/
multitenant/
index_19544/ (created Jul 07)
... (many directories)
index_19620/ (created today)
per_tenant/ (empty)
scratch/ (empty)
wal/
1695242727/ (created today)
00000000 (created today, 7866 bytes)
rules/ (empty)
tsdb-cache/
index_19539 (created today)
index_19620 (created today)
Here is my relevant configuration:
common:
storage:
gcs:
bucket_name: <bucket_name>
schema_config:
configs:
store: boltdb
object_store: filesystem
schema: v11
index:
prefix: index_
period: 168h
store: tsdb
object_store: gcs
schema: v12
index:
prefix: index_
period: 24h
storage_config:
boltdb:
directory: /loki-volume/loki/index
filesystem:
directory: /loki-volume/loki/chunks
tsdb_shipper:
active_index_directory: /loki-volume/loki/index
shared_store: gcs
cache_location: /loki-volume/loki/tsdb-cache
Would my cluster continue to run properly if I removed:
- the older schema config
- the boltdb storage config
- the filesystem storage config
- the tsdb_shipper.cache_location
- the persistent volumes
I assume that the contents of the active_index_directory are ephemeral and will be recreated if the instance is terminated or moved to a different node.
