I have configured an agent in flow mode to get logs from docker containers. (see config below)
All the default labels from discover.docker / loki.docker seems not being forwarded to loki.
Documentation is not really clear on how to set this up.
I know how to extract details from the log itself, but my question is more about the default labels from the docker container. How do I add these as labels?
discovery.docker "linux" {
host = "unix:///var/run/docker.sock"
loki.source.docker "default" {
targets = discovery.docker.linux.targets
forward_to = [loki.process.logs.receiver]
loki.process "logs" {
forward_to = [loki.write.local.receiver]
stage.docker {}
stage.static_labels {
values = {
env = "TEST",
loki.write "local" {
endpoint {
url = "http://host:3100/loki/api/v1/push"
