I am following this tutorial to implement : Configure Azure AD OAuth2 authentication | Grafana documentation
I have added https://community.grafana.com/login/azuread
and https://community.grafana.com
as redirect uri. I am starting the azure application as a docker image in port 3000. The configuration file is as follows:
[auth.azuread]
name = Azure AD
enabled = true
allow_sign_up = true
auto_login = true
client_id =
client_secret =
scopes = openid email profile
auth_url = https://login.microsoftonline.com/<tenant_id>/oauth2/v2.0/authorize
token_url = https://login.microsoftonline.com/<tenant_id>/oauth2/v2.0/token
allowed_domains =
allowed_groups = grp1 grp2
role_attribute_strict = true
allow_assign_grafana_admin = true
skip_org_role_sync = false
[log]
level = "debug"
I am curious to intercept the access token . I know that we get the authorization code from auth_url
and then we send it to the redirect uri and somehow the token_url
is used for authentication.
I wanted to know do I need to implement my own callback function overriding the route /login/azuread
I tried looking for the inplementation of /login/azuread
inside the docker image or the github repo but didnot find any .
So, my question is do i need to implement my own api that will capture the authorization token and forward it to token_url
