(Latest OSS, Linux) - What are you trying to achieve?
Is there any way to Disconnect values based on a dynamic threshold?
E.g. if it is higher than the windowPeriod? - How are you trying to achieve it?
Tried to use ${v.windowPeriod} - What happened?
Did just disable any threshold! - What did you expect to happen?
Uses the dynamic threshold.
