Disable the Invite feature in Users tab on Grafana
v10.1.5
As per our strategy and team decision, we need to manage user access only via LDAP, and access should be given through the respective groups. Therefore, no org admin users should invite people through the invite option in the users tab.
Need expertise support.
  • What happened?
The invite button should disappear from the window or it should not work.
