Test data locale value is different from default function locale due to multiple executions of init.
Below is the code snippet
import { check, group, sleep } from ‘k6’;
import { SharedArray } from “k6/data”;
import papaparse from ‘404 - resource not found;
import { randomIntBetween } from ‘404 - resource not found;
const locale = locale_generator();
const csvProduct= new SharedArray(“Product”,function() {
console.log("TestData_locale= "+locale);
return papaparse.parse(open(‘./Test_Data/Product_choice_’+locale+‘.csv’), {header:false}).data;
export default function(){
group('indexPage', (_) =>
console.log("Index_locale= "+locale);
export function locale_generator(){
let country_selector=randomIntBetween(1,4);
switch(country_selector) {
case 1:
return 'en_gb';
case 2:
return 'fr_be';
case 3:
return 'fr_fr';
default:
return 'en_ie';
Output:
INFO[0001] TestData_locale= en_gb source=console
execution: local
script: .\ticket.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
- default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
INFO[0001] Index_locale= en_ie source=console
running (00m00.0s), 0/1 VUs, 1 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs 00m00.0s/10m0s 1/1 iters, 1 per VU
