v8.4.3
- What are you trying to achieve?
We have this metric to extract the number of errors of several contexts/jobs:
idelta(org_apache_camel_FailuresHandled{type="routes", route=~"\"(R03_invoke).*", context=~".*b-ibs.*"}[5m])
This metrics works well every time in Prometheus but when it runs in Grafana fails(result is 0) if the range of time is below to 16 min
- How are you trying to achieve it?
Executing the same function in Grafana and Prometheus
- What happened?
The value is different when we run the query in Prometheus and Grafana. Prometheus shows a value very much higher than 0 and Grafana shows 0 or gives a error
The same value in both platforms
- Can you copy/paste the configuration(s) that you are having problems with?
Query: idelta(org_apache_camel_FailuresHandled{type="routes", route=~"\"(R03_invoke).*", context=~".*b-ibs.*"}[5m])
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Grafana shows this error"Metric org_apache_camel_FailuresHandled is a counter. Try applying a rate() function"
- Did you follow any online instructions? If so, what is the URL?
No
