Hi!
I am currently developing a dataSource Plugin but I am struggling with the setting of the instanceSettings.url in the ConfigEditor.tsx. From what I understood from the examples and the documentation and another community post, the defaultUrl prop on the DataSourceHttpSettings component should automatically set the instanceSettings.url. This is not the case for me. The url I specified in the defaultUrl prop is displayed as the placeholder but is not set in the instanceSettings. So I still have to manually type the url, when configuring the datasource. Is this expected behaviour?
My code currently looks like this:
ConfigEditor.tsx:
interface Props extends DataSourcePluginOptionsEditorProps<MyDataSourceOptions> {}
export function ConfigEditor(props: Props) {
const { onOptionsChange, options } = props;
const onAPIKeyChange = (event: ChangeEvent<HTMLInputElement>) => {
const jsonData = {
...options.jsonData,
apiKey: event.currentTarget.value,
onOptionsChange({ ...options, jsonData });
const { jsonData } = options;
return (
<DataSourceHttpSettings
defaultUrl="https://api.test.com/v1"
dataSourceConfig={options}
onChange={onOptionsChange}
showAccessOptions={true}
<FieldSet label="API Key">
<InlineField required label="API Key" labelWidth={26}>
<Input
required
onChange={onAPIKeyChange}
value={jsonData.apiKey || ''}
placeholder="API Key"
width={40}
</InlineField>
</FieldSet>
datasource.ts:
export class DataSource extends DataSourceApi<MyQuery, MyDataSourceOptions> {
baseUrl: string;
apiKey: string;
constructor(instanceSettings: DataSourceInstanceSettings<MyDataSourceOptions>) {
super(instanceSettings);
this.apiKey = instanceSettings.jsonData.apiKey;
this.baseUrl = instanceSettings.url!;
async query(options: DataQueryRequest<MyQuery>): Promise<DataQueryResponse> {
const { range } = options;
const from = range!.from.valueOf();
const to = range!.to.valueOf();
// Return a constant for each query.
const data = options.targets.map((target) => {
return createDataFrame({
refId: target.refId,
fields: [
{ name: 'Time', values: [from, to], type: FieldType.time },
{ name: 'Value', values: [target.constant, target.constant], type: FieldType.number },
return { data };
async request(url: string, method: string, payload?: any) {
const options = {
url: this.baseUrl + url,
headers: { 'X-Api-Key': this.apiKey },
method: method,
const response = getBackendSrv().fetch(options);
return lastValueFrom(response);
async testDatasource() {
const response = await this.request('/licenses, 'GET');
if (response.status === 200) {
return {
status: 'success',
message: 'Datasource was setup successfully.',
} else {
return {
status: 'error',
message: response.statusText
? response.statusText
: 'An unexpected error occurred. Datasource not setup correctly.',
