hello,
i have Grafana 9.2.5 frontend running on a docker container , my backends are on IBM i V7R4 ,
no network problems ,
data often stop in the dashboards randomly though backend is always started on port 3333 and can be contacted …
i don’t see anything wrong in the container 's grafana logs, do you know where i can investigate on the backend side ?
thanks
hi
could you please copy and paste all relevant data using the panel --> more --> get help
workflow in the panel’s dropdown menu? This will help us mock up your data and reproduce your issue. It is important to our teams that issues get verified as reproducible before we formally mark them as bugs. Thank you!
here are more details and steps for copying your data over to this issue:
also, try increasing the verbosity of the Grafana server logs to debug and note any errors. For printing to console, set the console logs to debug as well. More info on troubleshooting Grafana issues here Troubleshooting | Grafana documentation
