Dashboard variable query get distinct labels with influxdb
    v9.3.6 (978237e7cb)
    I record temp/light/moist from several locations using influxdb and influxv2 language
    Each row is tagged with the location
    I want to get all the unique values of location tag, and make a dashboard variable for multi-selection
    I did create a dasnboard variable query, using this query :
from(bucket: "my-bucket")
  |> range(start: v.timeRangeStart, stop:v.timeRangeStop)
  |> filter(fn: (r) =>
    r._measurement == "my-measurement"
  |> distinct(column: "location")
  • What happened?
    I expected to get the 2 locations that I have records for now
    When using the “explore” tab, the very same query does return the expected rows, ie something like that :
_value
location_1
location_2
But both in dashboard view, or in dashboard config variable view, only 1 value (ie 1 row) shows up
    I expected both locations to be available as variable multi-choice, but only one does
    No sure if this question is relevant in my case
    No error message, quite the opposite, the very same query gives me expected result when using it in explore
    No instruction but doc on flux language distinct() function | Flux 0.x Documentation
Hi @bastien,
Can you try with listing unique tags with schema.tagValues function?
E.g. for listing cpu tags:
import "influxdata/influxdb/v1"
v1.tagValues(
    bucket: v.bucket,
    tag: "cpu",
    predicate: (r) => r._measurement == "cpu" and r._field == "usage_system" and r.cpu =~ /cpu[0-2]/,
    start: -1d
Note: Predictate is basically what you usually write in filter() function.
This returned:
Links:
Best regards,
ldrascic
Hi
I tried it and it worked, thanks :slight_smile:
Meanwhile, I also had found a way to do it :
from(bucket: "bucket")
  |> filter(fn: (r) =>
    and r._field == "temp"
  |> group()
  |> keep(columns: ["_time", "location"])
What I added from before :
  • group() I guess before that I had a stream of tables. With group() I get a table, and rows are taken as variable entries
  • keep(columns: ["_time", "location"]) which I understood is setting the values of location as default values. I’m not sure about the analogy here, because I understood that _value should be an int/float/bool but not a string
@ldrascic Am I write to think that tagValues() is a more efficient solution coz it’s a single call ?
Haaaa !
Turn out I RTFM thanks to @ldrascic link
It also works fine and is more clear like that :
import "influxdata/influxdb/schema"
schema.measurementTagValues(
    bucket: "bucket",
    tag: "location",
    measurement: "my-measurement",
    start: -1d
This may help you or others in the future.
