Are you using same time range
So does that mean that I have to gives up. The query runs fine for 30 days in InflxuDB, but times out in Grafana.
Can one open a bug submission for Grafana?
Before you do that…
120
seconds is still an issue for a 30 day span in any database. You should be getting subseconds speed if not few seconds only with some finetuning.
Next step is vetting your influxdb schema design and the use of the contains
filter
The rule with influxdb is as follows:
measurement
and tags
are indexed whereas fields
are not.
So you may want to configure object
as a tag (if not already) since you are filtering on it
The other issues you will need to tackle is the use of contains
which is notorious for performance issues in any query language. Other alternatives are found in this post
So once you have done your due diligence with best practices on the influx schema side of things and using something other than contains
function, you can then confidently create a bug for increasing timeouts
@mephisto, you created this dashboards for Proxmox! Where are you when I need you?
did you setup the influxdb yourself?
Yes, I did. I following the instructions to set it up for Proxmox. I’m busy learning basics of the query language and have fixed on of the graphs already by making the changes you linked me to.
New query using regex:
filter(fn: (r) => r[“nodename”] =~ /${server:regex}/)
which was before:
filter(fn: (r) => contains(value: r[“nodename”], set: ${server:json}))
Can’t wait for @mephisto forever now, can I?
nope. is nodename
a field or a tag?
create a bucket + token in influxdb2
enable metric export in Proxmox VE. <--- this section is a concern
how much faster is your query now with the regex change
I see there is a new version of the Dashboard at Proxmox Cluster [Flux] | Grafana Labs which has dropped the “contains” from the queries.
It has a downside in that one cannot select stats for the whole cluster, but only for one host at a time, but at least I can get stats for 30 days.
So I’m going to close the thread now. My objective is not to learn Flux at this stage, but to simply use the dashboard, so the pressing problem has been resolved.
