latest -
I need to clean up some resources in my backend datasource plugin when the user navigates away of from one dashboard to another or when he/she has closed the dashboard. -
I am looking for Grafana dashboard events by which I can send a signal to my backend datasource on dashboard close to clean up server side resources (in Golang). -
What happened?
Any help on this is appreciated -
NA -
NA -
NA -
NA
