Custom Label parsing in Loki
We have syslog logs forwarded via Logstash Output Loki plugin.
How do we extract fields from logs into custom labels/filters.
You have two choices:
  1. Parse logs live on Loki. You can do this via LogQL, which is quite good.
  2. You can parse logs in logstash and set labels there as well.
You do want to avoid overdoing it on labels if you parse on logstash, see Label best practices | Grafana Loki documentation for some general guidelines.
