I’m trying to calculate a gauge displaying the cumulative log weight in MB since Today ingested from loki. I saw the metrics bytes_over_time but I don’t know if this is correct:
sum by (job) (bytes_over_time({job=“stage-aws-ubipush-apm”}[$__interval]) / 1000000)
There was a threshold (80) that can be set both as Absoloute or percentange that I removed and the max thresholds actually overlaps the max value of the metric that is what I would like to see. I choosed to see always max in this case
