I’m working with ELK version
"version" : {
"number" : "8.6.1",
"build_flavor" : "default",
"build_type" : "rpm",
"build_hash" : "180c9830da956993e59e2cd70eb32b5e383ea42c",
"build_date" : "2023-01-24T21:35:11.506992272Z",
"build_snapshot" : false,
"lucene_version" : "9.4.2",
"minimum_wire_compatibility_version" : "7.17.0",
"minimum_index_compatibility_version" : "7.0.0"
and Grafana version
$ /usr/sbin/grafana-server -v
Version 9.5.2 (commit: cfcea75916, branch: HEAD)
I get in the Grafana the error below
"Elasticsearch error: Cross-cluster calls are not supported in this context but remote indices were requested: [2023-07-31T00:00:00Z]"
The datasources looks as following:
"id": 259,
"uid": "jFl5w9lVk",
"orgId": 2,
"name": "XXX_XXXXXXX",
"type": "elasticsearch",
"typeLogoUrl": "",
"access": "proxy",
"url": "localhost:9200",
"user": "",
"database": "",
"basicAuth": true,
"basicAuthUser": "xxxxxxx",
"withCredentials": false,
"isDefault": false,
"jsonData": {
"database": "[xxxx_sssss-AAAA_]YYYY.MM.DD",
"esVersion": "8.0.0",
"includeFrozen": false,
"interval": "Daily",
"logLevelField": "",
"logMessageField": "",
"maxConcurrentShardRequests": 1,
"timeField": "TIME",
"timeInterval": "1m",
"tlsAuth": false,
"tlsSkipVerify": false
"secureJsonFields": {
"basicAuthPassword": true
"version": 2,
"readOnly": false
In the dashboard I see the error as in the attached.
No error in the ELK log.
In the Grafana I see only the below error:
logger=grafana.update.checker t=2023-07-31T18:26:57.425465448+03:00 level=error msg="Update check failed" error="failed to get latest.json repo from github .com: Get \"//raw.githubusercontent.com/grafana/grafana/main/latest.json\": dial tcp: lookup raw .githubusercontent .com on xx.xxx.xxx.x:53: no such host" duration=3.567989ms
Elasticsearch yml:
[root@xxxxxxxx elasticsearch]# cat elasticsearch.yml |grep -v ^#
path.data: /xxxxxxxxxxxxxx/XXXXXXXXXX
path.logs: /var/log/elasticsearch
network.host: 0.0.0.0
http.port: 9200
discovery.type: single-node
xpack.security.enabled: false
xpack.security.enrollment.enabled: false
xpack.security.http.ssl:
enabled: false
xpack.security.transport.ssl:
enabled: false
http.host: 0.0.0.0
search.max_buckets: 100000
action.destructive_requires_name: false
ingest.geoip.downloader.enabled: false
Elasticsearch jvm config file:
[root@xxxxxxxx elasticsearch]# less jvm.options |grep -v ^#
-Xms14g
-Xms14g
-XX:+UseG1GC
-Djava.io.tmpdir=${ES_TMPDIR}
-XX:+HeapDumpOnOutOfMemoryError
-XX:+ExitOnOutOfMemoryError
-XX:HeapDumpPath=/var/lib/elasticsearch
-XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log
-Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m
any hint/help will be great.
THANK YOU!!
