Grafana 7.0 in a Ubuntu 18.04LTS -
Visualize Azure NSG Flow Logs -
NSG flow logs are enabled using Network Watcher and are stored in Azure blob storage. A Logstash plugin is used to connect and process flow logs from blob storage and send them to ElasticSearch. Once the flow logs are stored in ElasticSearch, they can be analyzed and visualized into customized dashboards in Grafana. -
What happened?
All the configurations on all 3 tools are done. Grafana is able to see the logs. However, I can’t get the right query to visualize in a Graph. -
As the procedure is showing, I was expecting to have the same output from the Graph dashboard. -
No problem at all. I think it is a lack of information regarding the query configuration to achieve the result that we are aimeing. -
No -
Manage NSG Flow Logs using Grafana - Azure Network Watcher | Microsoft Docs
