Hello Team,
We are facing an issue in the alloy version - v1.9.2 with CPU readiness metrics in Grafana Alloy using the vCenter integration. The data is being ingested into Mimir successfully , however the CPU readiness metric consistently reports a value of 0.
Below are the troubleshooting steps and observations so far:
Verified the Alloy configuration for the vCenter integration by running Alloy in debug mode; however, the root cause could not be identified.
Updated and re-deployed the Alloy configuration multiple times, but the issue persists.
Adjusted the collection interval to evaluate the impact:
- Initially set to 30 seconds
- Reduced to 10 seconds
- Also tested with a 2-minute interval, which helped smoothen spikes, but the CPU readiness values are still consistently reported as 0.
In Splunk, the CPU readiness metric is observed in milliseconds, whereas Alloy appears to scrape and forward only percentage-based CPU readiness values.
Could you please help us with the following:
- Why is CPU readiness always reported as 0 in Alloy?
- Does Alloy support CPU readiness metrics in milliseconds for vCenter?
- Is there any specific configuration or metric mapping required to obtain accurate CPU readiness values?
